×I've used jira for a while and have recently setup a team-managed project. I've run into some quite baffling/frustrating issues:
What am I missing with respect to columns and statuses? They would appear to do/be the same thing. But I find them utterly non-intuitive.
In simple words
Columns are used to display the issues and issues will land into columns based on the status we mapped on the board. Nothing more
For automation to work, you should have a proper transition for the issue to make which is associated with the workflow.
Check the workflow and create the automation
Let me know if you have any queries
Thanks Pramodh. But this is not what I experience. I have mapped Statuses to columns. But let's say I have a ticket in the backlog and I change its status to In Progress, the ticket does not move. It just stays in the backlog.
Hi @Ben Merven ,
You could have several statuses mapped to one column. E.g. I have 'In progress' and 'in review' linked to the the 'in progress' column, and when I drag and drop an issue I can select the section in the column:
Thanks Carlos, but I want it the other way around. I want a ticket to have a status of "In Progress" , but then visually move it across the board through different columns.
Eg: for column (top) and status (bottom)
| In Progress | Testing | QA |
| In Progress | In Progress | In Progress |
Further to your point, even if mapping multiple statuses to one column, it seems it is not possible to display the status in the card view when using next-gen/team-managed projects.
