What's the best way to create test plans for a JIRA scrum project
martin griffiths May 6, 2022
We have an In Testing status in our JIRA scrum board, but it's proving a little cumbersome to maintain and complete. What's the best way to create test plans for manual completion from a JIRA Scrum board?
Jarosław Solecki [Deviniti]
@martin griffiths like it is already said, probably the best solution would be some plugin for Jira.
I could recommend Requirements and Test Management for Jira as it has a quite straightforward process with easy linking of Test Cases with Test Plans.
Nic Brough -Adaptavist-
May 6, 2022
I would look at the various test management apps in the market place, although you would probably only need one of the lighter ones.
