×Scenario:
Do you:
The ideal solution is "everything should be fixed before a deployment and your testing / CI should pick this up before it happens", but this is not the reality.
I suppose that this is fairly dependent upon my workflow, which I've attached. We haven't begun the crux of our Jira migration yet so this workflow is highly theoretical and isn't remotely set in stone, so I'm happy to take "your workflow is wrong, and here's why" as an answer. However I've determined that Jira Software's 'Releases' functionality expects issues to be resolved before you can release (it'll let you, but it'll whinge about it first, so I suspect that it's not something I should be doing). So please keep this in mind.
Any and all help is appreciated. Thank you.
Hi @Kye Russell
I think this is really a question of what process you want to follow.
In my experience different teams worked this out in different ways. Some would push the issue back to dev status and unset the Resolution. Others would raise a new ticket for the patching work. The latter is a bit cleaner in my opinion and will give you a picture of how many repeats you do. I also had a team request a workflow step to allow them to edit a Resolved issue to set it to ‘Failed’ Resolution with a reason entered.
Most of the workflows I’ve set up for dev teams have a Test or QA status. That won’t prevent failed deployments on its own. But it does record who approved it and you can dig in to what the weak points are in the process.
