What will happen to Jira and its add-ons once maintenance expires?
Iana
I would like to know if Jira and Jira Service Management continue to work normally after their Server license expires or is there an downgrade of functionalities?
What happens to the add-ons/plug-ins we use? Do they also continue to work?
Iana
Fabio Racobaldo _Herzum_
Hi @Iana ,
jira server has a perpetual license so you can continue to work but without support/available upgrade.
Add-ons license depends from the app itself. Some of them are perpetual and others will not work after expiration.
For JIRA DC instance, instead, you can not use jira after the license expiration.
Hope this clarifies your doubts,
Fabio
ViswanathanR April 27, 2023
the add-ons will stop working and you will get license expiry message.
But Data centre trial licenses for add-ons can be installed and it will work.
However, it is highly recommended that licenses are purchased..
Sushant Verma
Hi @Iana
As all commercial and academic licenses are perpetual. Your JIRA will continue to work as it did  it expired.
There are some minor differences. Hope below document helps you :
https://www.atlassian.com/licensing/purchase-licensing#trials
Sushant Verma
Sreenivasaraju P
January 12, 2023
Hi @Iana ,
Jira server product license is perpetual. You can use them even after expiry of license. No functionality downgrade.
You will not get support and upgrades. Any how after Feb 2024, no support from Atlassian for server products.
Regarding add-on, please check with respective vendors. Most of the add-ons stop working, as per my knowledge.
