one of my company s PO asked me if there is a way to sum up all efforts for a certain epic and all linked stories and sub-tasks.
I searched in the report area of the projects but there are only reports on a user or version basis available. I also tried to find a plugin but found nothing obviuos. I know I could probably do with JQL and MS Excel export, but the PO definetely wants an integrated solution.
We are using Jira Agile and Tempo. I hope that somebody can point me in the right direction. Any help is very appreciated.
Best Regards,
Christian
Hi All,
I actually found a solution myself. I played around with the Script Runner Plugin/Scripted Custom Field - thank you Jamie for this Swiss Army Knife for JIRA :-)
I just wrote a script that crawls over a specific link type ("has Story") linked issues and their sub tasks summing up the time spent fields if any work logs have been provided.
It is a little bit hard-coded at the moment so there still is room for improvement:
import com.atlassian.jira.ComponentManager def componentManager = ComponentManager.getInstance() def issueLinkManager = componentManager.getIssueLinkManager() def totalTimeSpent = 0 def resultHTML = "<ul>" def epicTimeSpentString = "No Work Logs" def epicTimeSpent = issue.timeSpent if(epicTimeSpent) { epicTimeSpentString = componentManager.getJiraDurationUtils().getFormattedDuration(epicTimeSpent) totalTimeSpent += epicTimeSpent } resultHTML += "<li><b>This " + issue.issueTypeObject.name + ": " + epicTimeSpentString + "</b></li>" if(issue.getSubTaskObjects().size > 0) { resultHTML += "<ul>" issue.getSubTaskObjects().each {epicSubTask -> def epicSubTaskTimeSpentString = "No Work Logs" def epicSubTaskTimeSpent = epicSubTask.timeSpent if(epicSubTaskTimeSpent) { epicSubTaskTimeSpentString = componentManager.getJiraDurationUtils().getFormattedDuration(epicSubTaskTimeSpent) totalTimeSpent += epicSubTaskTimeSpent } resultHTML += "<li>" + epicSubTask.issueTypeObject.name + " - " + epicSubTask.key + " - " + epicSubTask.summary + " - <b>" + epicSubTaskTimeSpentString + "</b></li>" } resultHTML += "</ul>" } issueLinkManager.getOutwardLinks(issue.id).each {issueLink -> if (issueLink.issueLinkType.name == "Epic to User Story") { def linkedIssue = issueLink.destinationObject def linkedIssueTimeSpent = linkedIssue.timeSpent def linkedIssueTimeSpentString = "No Work Logs" if(linkedIssueTimeSpent) { linkedIssueTimeSpentString = componentManager.getJiraDurationUtils().getFormattedDuration(linkedIssueTimeSpent) totalTimeSpent += linkedIssueTimeSpent } //resultHTML += "<li>" + issueLink.issueLinkType.name + " - " + linkedIssue.key + " - " + linkedIssueTimeSpentString +"<br/></li>" resultHTML += "<li>" + linkedIssue.issueTypeObject.name + " - " + linkedIssue.key + " - " + linkedIssue.summary + " - <b>" + linkedIssueTimeSpentString +"</b></li>" if(linkedIssue.getSubTaskObjects().size > 0) { resultHTML += "<ul>" linkedIssue.getSubTaskObjects().each {linkedIssueSubTask -> def linkedIssueSubTaskTimeSpentString = "No Work Logs" def linkedIssueSubTaskTimeSpent = linkedIssueSubTask.timeSpent if(linkedIssueSubTaskTimeSpent) { linkedIssueSubTaskTimeSpentString = componentManager.getJiraDurationUtils().getFormattedDuration(linkedIssueSubTaskTimeSpent) totalTimeSpent += linkedIssueSubTaskTimeSpent } resultHTML += "<li>" + linkedIssueSubTask.issueTypeObject.name + " - " + linkedIssueSubTask.key + " - " + linkedIssueSubTask.summary + " - <b>" + linkedIssueSubTaskTimeSpentString + "</b></li>" } resultHTML += "</ul>" } } } resultHTML += "</ul><br/>" def totalTimeSpentString = totalTimeSpent ? componentManager.getJiraDurationUtils().getFormattedDuration(totalTimeSpent) : "No Work Logs" resultHTML += "<h4>" + totalTimeSpentString + "</h4>" return resultHTML
I use two variants of this full output script to just provide a formatted string with the calculated sum and a plain number output so that further calculations are possible with escel exports.
I realize that this could produce a lot of output for complex relationships (one epic with a lot of stories and a lot of sub tasks) and that this could be quite permormance consuming. But in general it is doing what was requested and I will have an eye on performance issues. My PO is happy now :-)
Please feel free to re-use and let me know of any improvements! :-)
Best Regards,
Christian
Perfect! I am glad this helped you! :-)
Uh Thanks very much that was fast.
Yeah i figured that this link traversing might have performance issues. But having to count the worklog manually is a even bigger performance issue ;-)
Btw: Worked for me except that our Epic Links have different name. So i had to use the line
issueLink.issueLinkType.name == "Epic-Story Link"
Hi Riad,
this would be the version with the plain number:
import com.atlassian.jira.ComponentManager import java.text.DecimalFormat def componentManager = ComponentManager.getInstance() def issueLinkManager = componentManager.getIssueLinkManager() def totalTimeSpent = 0.0d def epicTimeSpent = issue.timeSpent if(epicTimeSpent) { totalTimeSpent += epicTimeSpent } if(issue.getSubTaskObjects() != []) { issue.getSubTaskObjects().each {epicSubTask -> def epicSubTaskTimeSpent = epicSubTask.timeSpent if(epicSubTaskTimeSpent) { totalTimeSpent += epicSubTaskTimeSpent } } } if(issueLinkManager.getOutwardLinks(issue.id) != []) { issueLinkManager.getOutwardLinks(issue.id).each {issueLink -> if (issueLink.issueLinkType.name == "Epic to User Story") { def linkedIssue = issueLink.destinationObject def linkedIssueTimeSpent = linkedIssue.timeSpent if(linkedIssueTimeSpent) { totalTimeSpent += linkedIssueTimeSpent } //if(linkedIssue.getSubTaskObjects().size > 0) { if(linkedIssue.getSubTaskObjects() != []) { linkedIssue.getSubTaskObjects().each {linkedIssueSubTask -> def linkedIssueSubTaskTimeSpent = linkedIssueSubTask.timeSpent if(linkedIssueSubTaskTimeSpent) { totalTimeSpent += linkedIssueSubTaskTimeSpent } } } } } } if(totalTimeSpent > 0) { totalTimeSpent = totalTimeSpent / 60.0d / 60.0d / 8.0d //Seconds to Hours } //formatNumber(number: totalTimeSpent, Locale.ENGLISH, format: '##0.0') //new DecimalFormat("#.#").format(totalTimeSpent); totalTimeSpent
Please keep in mind that this can cause high load on your jira instance - so handle with care! Meanwhile I would recomment evaluating the Structure-Plugin or EazyBI.
Kind Regards,
Christian
This might excatly what i was looking for. I try it out and give you some feedback how it worked for me.
Any chance you could post your second variant? Since i am lazy ;-)
Hi Riad,
Kind Regards,
Christian
Ah - and the Script Runner Plugin is also available ;-)
