When Jira 7 will it be compliance with PosgreSQL v9.5
BNT
November 23, 2016
Hi, my PostgreSQL installation is 9.5, (soon 9.6), when JIRA will it be compliance with 9.5?
I would like to update my Jira installation and change DB to PostgreSQL
best regards
Andrea Bontagnoli
doc:
https://confluence.atlassian.com/adminjiraserver070/supported-platforms-749382629.html
Nic Brough -Adaptavist-
November 23, 2016
I'm afraid they're not supported.  Officially, they are not compatible, so Atlassian won't support you running them on 9.5 or 9.6.  I can't tell you when support is expected, Atlassian will say "when it's ready"
BNT
November 23, 2016
Thank's Nic,
I found that JIRA version 7.2 at this moment is compliance with the PostgreSQL 9.4 one (https://confluence.atlassian.com/adminjiraserver072/supported-platforms-828787550.html)
Little better step that the proposed situation before
B.
Andrea Bontagnoli August 16, 2017
Migrated to Jira 7.4 after passing from Oracle 10c to Oracle 12g and then migrate to PostrgreSQL 9.5.6
