When creating an automation, is there a way to copy the component and the corresponding field?
Darrian Castillo April 18, 2022
Hi all! Me again!
I have created an automation that when a "EPIC" is created "TASKS" will be created. In my case the EPIC will have 30 related tasks and within each task there are 16 fields that need to be pulled over from the trigger issue. I noticed that i have to configure each component manually to reflect the above. Is there any way I can just copy the component with the 16v field links? so i don't have to create each component manually?
SEE YELLOPW BELOW
Piotr Zadrożny _Eyzee_
Hi @Darrian Castillo
As far as I know, you can't copy the automation rule component - but you can use JSON to provide field configuration. Please take a look at this documentation: https://support.atlassian.com/cloud-automation/docs/advanced-field-editing-using-json/, it should clear things out.
Best,
Piotr
