When do Issues move out of my backlog
Deleted user October 19, 2020
I'd like to know when issues will not show up in the backlog anymore at any time.
Is there some filter on this? "done" status for example?
Reason for my asking is:
  • I want to create a project for "feature requests";
  • This project does not need a scrum of kanban board;
  • With automation rules, I'd like to:
    • When issue is done;
    • Move (or copy) the issue to the developer-team-project;
    • I need to be sure the issue is not "moved outside the backlog", since it is "done".
I've had this question before, but it wasn't urgent.
So, the above is easily testable and probably doable in any way. Still, I'd like to know when issues can no longer appear on the backlog.
(working in SCRUM project, FYI)
Thanks!
Warren
October 19, 2020
Hi @[deleted]
If you're using a Scrum project, I believe that the only time it will stop showing in the Backlog view is when it is "closed" i.e. has the status of the right hand column of the board. This applies whether you add the issue to a sprint and progress it through the workflow or even if you progress it through the workflow whilst still "in the Backlog".
Deleted user October 20, 2020
Is there, as far as you know, a field in which this "closed" status is saved? Can I change it manually?
Warren
October 20, 2020
Hi @[deleted]
No it is the final status in the workflow.
You could change the workflow to only have 2 states, Backlog and Closed, so that the moment you change the status, it is closed and wouldn't show in the Backlog view.
Ah. So it is "done" status for us.
And if I would change the "done" status to "in progress", would that bring the issue back to my backlog then?
Warren
October 20, 2020
Hi @[deleted]
Sorry, different instances of Jira have different status names, so Closed = Done = ...
Yes, if you were to "reopen" an issue, i.e. change it from Done to In Progress, it would again show in the Backlog
Like Deleted user likes this
