When i create Two Dimensional dashboard with projects against fix version i get repetition of fix versions
Ecom jira April 2, 2014
When i create Two Dimensional dashboard with projects against fix version i get repetition of fix versions. I used the below query to create a dashboard.
project in ("XXX", "YYY","ZZZ ") AND fixVersion was in(AAA,BBB,CCC)
I Wanted a dasboard which looks like
Fix Version Project
XXX YYY ZZZ
AAA 5 2 3
BBB 7 8 0
CCC 5 6 7
I achieve it using any fileds but not with Fix version/Components. Is there a limitation with Fix versions/Components since its project specific? Please help me remove redundancy of Fix versions.
Nic Brough -Adaptavist-
April 2, 2014
It doesn't matter what you call a version (or component), it's a separate entity from all the other versions.
If, for example, you create versions called x1, y2 and z3 in project ABC, and y1, y2 and y3 in project ZYX, then you have six versions in total. It doesn't matter that you've only got five unique names, you have six versions.
April 2, 2014
As I said, the name or label you put on a version doesn't matter. The versions belong to the projects.
You can't "fix the query" because the query is returning data that contains a set of "versions". The fact some of them have the same label is completely irrelevant.
You'd need to hack the gadget so that it groups by name of version and not version object (which would be a disaster for some of us, because we need versions to be separate, even when they do have the same name)
There are requests for "global versions" to be implemented in Jira, but I don't see them high on Atlassian's to-do lists.
If there is fix version y2 ,y3 common across many projects will there still be a repetition? Will it consider as unique fix versions specific to a particular project? Is there any way where i can edit the query ?
April 11, 2014
That sees the versions in the same way - they're separate objects.
Ecom jira April 10, 2014
Thanks Nic. Can anyone suggest me if the Power report plugin for Jira will solve this problem?
