I am considering the approval of a bump-up to 20MB for max size for attachments in JIRA. Instructions for doing so are here, but there is no contextual guidance for an acceptable range before you might experience negative results in performance:
http://confluence.atlassian.com/display/JIRA/Configuring+File+Attachments
The reasons for doing so are that I have teams with large log files that they don't want to push into document repositories due to inconvenience and overhead of doing so. Other scenarios I could imagine would be attaching larger presentations or vids to issues.
If 10MB is the assumed sweet-spot, does anyone have anecdotal feedback on pushing past this and discovering thresholds for when performance degrades marginally (i.e. maybe 50MB - It's a bad idea to move past this) and then significantly (i.e. maybe 100MB - If you do this, you will kill your instance)? Or are there too many factors at play in individual system set-ups to make shared observations relevant?
I don't think it makes a blind bit of difference to performance, and I doubt there is a tipping point. All jira is needs to do is stream the file when the client requests... not demanding.
Obviously it will have an effect on the disk space you require, but I presume you've factored that in.
The only possible difference is, there is a plugin that indexes attachments, which would push up the size of your index. I wouldn't recommend using this plugin if you are storing large log files.
I don't think 10Mb is a sweet spot, it's just an arbitrary round number.
Note s.a.c allows attachments up to 250Mb - if there was a problem they wouldn't do this.
Thanks, Jamie!
Thanks Beth ;-)
Hi Jamie, I wanted to follow up on this thread. We have a new requirement where some of our users would like to attach core dump files to their defects. The file size is 2GB! We agree that the download is not of concern. We are concered with possible performance impacts when uploading files of that size. Any suggestions or guidance would be greatly appreciated.
