When the change from issue to work happens will we have to update all our filters?
Andrew Hoffman
February 7, 2025
I was reading over the UI changes coming in March. You are changing the terminology from "Issue" to "Work" - will we need to update our filters to accommodate this?
Tomislav Sablic
It will change the UI terminology from "Issue" to "Work". The issue types or work types would stay the same how you configured it, so there is no need to update that.
JQL functions such as ... issuetype in ...  should work and I am almost certain that if it were to change, it would be done without your intervention.
Matt Doar _Adaptavist_
Forcing all customers to change all their filters manually would be ... unhelpful for any product. So I hope it will just continue to work.
Like Tomislav Sablic likes this
