When using WBS Gant Chart to upload a MS Project schedule into Jira all of the tasks are imported backwards for example with the 1st task last and the last task first. Why is this and are there setting within WBS Gant Chart or Jira to prevent this?
Can you check "View link in reverse" and see if the problem will be solved?
Jira configuration > Apps > WBS GANTT-CHART > Issue > Edit > Check "View link in reverse" > Update
Thank you very much. That was the issue.
