Where is Plan Mode/ Work Mode?
Wendy He
July 28, 2016
I'm using Cloud (not the server) and I do believe I have Agile but on the top bar, there is no Agile dropdown or plan mode/work mode. I could be wrong, but is there a way to see if I have JIRA Software/Agile and what version I have. Is there a way to turn on plan mode/work mode and have the Agile dropdown on the top bar if I do have JIRA Agile?
Let me know, thanks.
Steve Behnke [DiscoverEquip.com]
July 28, 2016
The add-on has changed, I'll describe the difference –
The JIRA Agile add-on is now part of the JIRA Software Application. Instead of Agile in your header, you will now have Boards. This is pretty much the same as it was before.
image2016-7-28 9:8:23.png
Boards are now associated with Projects, so you'll see the Board and the Project Sidebar at the same time. The Plan/Work mode buttons are now on the Project Sidebar, named Backlog and Active Sprint.
image2016-7-28 9:10:47.png
Wendy He
July 28, 2016
Thanks Steve,
But can I still plan multiple sprints? Where is that option?
July 28, 2016
If you're referring to Parallel Sprints, you can now find this option under –
  1. JIRA Administration from the top bar >  Applications, then scroll down the page to the JIRA Software section.
  2. Under JIRA Software configuration, select the Parallel Sprints checkbox.
https://confluence.atlassian.com/jirasoftwarecloud/using-parallel-sprints-797737030.html
