Which permission is required to see and manage billing in Jira. I am having Site admin access. Still not able to see the billing. Please advise which access or permission is required to access billing apart from Org Admin.
Hi @Vivek Tiwari ,
You can add a Billing admin to your Atlassian Org, documentation for reference: https://support.atlassian.com/subscriptions-and-billing/docs/understand-billing-administration/
Extract that is imp. for your use case:
To add a billing admin:
From the left navigation, select Billing admins.
Select Add a billing admin.
Enter the email address and select Add admin.
To add multiple billing admins for the same account, they must be added one at a time. You can’t add a distribution list.
You would need billing admin. The current user that is billing admin can add you as a billing admin
