×Hi,
Im a new admin and one of my mission is to find a cheaper solution to export all details of an issue from JIRA. For now we only have an export PDF option that is expensive. We are just wondering if there is a cheaper solution out there. The idea is to use those export when we have an audit.
Thanks a lot in advance for your kind help.
Pauline
Export to word is a built-in option that gives you a view of the whole issue.
I think we need more context as to what you're trying to do and why?
Pauline,
What tool are you currently using?
When you say that you want to export the details, what do you mean? Does that just need to include all the field values? The field values, change history, comments?
How is the data being consumed? IE, does the form matter as long as the details are present?
If you could please provide some additional details about what you would like to do, I'm sure we can come up with a few ideas!
Thanks!
Kian
