While running JQL, Why jira showing only 10 errors in output.
Not getting all not matching key at a time.
Unfortunately this is standard Jira behaviour to limit reported errors. You may find more errors listed on the logs but I would not bet on it.
The FixVersion entries look like project keys unless tat is how to choose to name your fixVersions.
The only solution to to remove those bad values, run and repeat until you get a clean query.
Hi @Tom Lister
Thanks for your response.
Yes - from last 3 years I am following same process to remove bad/not matching project keys. On Daily/Weekly basis i have to extract Defects/Test Executions against 300 projects. Finally it's very difficult and time taking activity.
