I'm new to Jira, and I'm learning the software independently. There are a few things I need help with.
For instance, i need help to split the "In Progress" column into 3. There are a few more things like this I need help on.
Any help would be great.
Cherrelle, do you want to add additional statuses beyond In Progress?
Maybe this will help you https://support.atlassian.com/jira-software-cloud/docs/configure-columns/
Yes? what's next :-)
Good luck!
