Why Forge UI modifications example is not working?
matiasmolinas December 3, 2022
Hi all I am very interested on start to use the new UI modifications feature, but after deploy the Forge UI modifications example I only can see on my Jira Cloud project I following the steps in the project page:
https://bitbucket.org/atlassian/forge-ui-modifications-example/src/master/
There is no change on me create issue page on Jira. Is it necessary an additional configuration step? Is is available in Jira Cloud?
Also the Jira issues for this project are not working:
https://bitbucket.org/atlassian/forge-ui-modifications-example/jira?statuses=new&statuses=indeterminate&sort=-updated&page=1
Victor Debone
December 6, 2022
Hi @matiasmolinas !
UI Modifications are a bit of an unusual Forge module, as in it requires some more steps to work, because once it is installed you will need to attach it to the context of a project and issue type.
With the example app, you can make that action from the admin panel. This admin panel will be found on the apps management page in Jira, on the sidebar. There, you will be able to create a UI modification and attach it to a context. Only then you will see the UI modifications that are defined in the UI modification Custom UI app.
If you need more guidance with UI modifications, we have a guide Understanding UI modifications.
I hope that helps :)
matiasmolinas December 7, 2022
Hi @Victor Debone
Thanks, yes it's working now. Thank you for your clarification
Dilshad Shaikh
July 22, 2024
Hello @matiasmolinas  did you find a solution to enable UI modification code for free instance?
matiasmolinas December 5, 2022
Hello @Trudy Claspill Thanks for your help, I will be waiting for the answer
Trudy Claspill
Did you fulfill the requirements specified in the Readme file?
Requirements
  • See Set up Forge for instructions to get set up.
  • Jira instance prerequisites:
Hello
The only thing I am not sure about is this:
  • UI modifications integration code enabled. This feature can only be enabled by Atlassian.
How can I check this, or ask for it if necessary?
Trudy Claspill
Open a case with Atlassian support to ask about that:
https://support.atlassian.com/contact/#/
matiasmolinas December 4, 2022
Thanks!!
OK, I followed the link but I don't see a way to open a case. I am using the cloud free version for development. Is it possible to develop extensions with this version?
Hey Atlassian Development Team, I'm eager to get UI Modifications up and running so I can provide you with feedback! Can you help me get it enabled or explain why the example I followed isn't working? Thanks in advance!
Trudy Claspill
If you are using the Free version then you don't have access to open support cases.
I'll see if I can get an Atlassian Team Member to check on this.
Hello @Trudy Claspill Thanks for your help, I'll be waiting for the answer
FREE
