Has anyone else seen this, I swicth to another dashboard from favourites list down the left-side of the screen & am immediately presented with the 'you do not have permission to see this, you may need to login', if I login the dashboard displays correctly.
It also happens occassionally when clicking through to the project summary page by clicking on the project name.
Cheers
Norman
No, all the gadgets/filters on the dashboard are owned by the project. Also, strangely, it hasn't happened for the lst 20mins - off to trawl through the logs I guess :-(
Do you have any admin related gadgets on one of your dashboard? sudo access might be playing with you here
Doesn't seem to, for ex. I'm on this page
http://jira.xxx.com/secure/Dashboard.jspa?selectPageId=10141
and switch to another dashboard and the url for that is
http://jira.xxx.com/secure/Dashboard.jspa?selectPageId=10147
and now it's working again intermittantly :-( I wonder if something else is molesting the cookie?
Does the url change when you do that? If the base url differs then your cookie will not be valid possibly.
