Why are JIRA issues from branches not showing as linked to Bamboo builds and releases?
johntholland February 10, 2015
First, we are creating a new branch from JIRA in bitbucket and leaving the JIRA key in tact. As an example, a new branch might be UNITCLASS-5-code-cleanup.
Then, we are fixing the issue, creating a pull request, and merging into the main branch.
Then, Bamboo builds it. However, it does not pick up the affected JIRA issues under the build or release.
So we have this commit message which is detected as a new change for the build:
Merged in UNITCLASS-5-code-cleanup (pull request #9)
However, there are no new JIRA issues reported. It does see a JIRA issue linked if we explicitly add UNITCLASS-5 for example to the commit, but not if the commit has the full branch name, including the JIRA key.
Why is this not showing up?
Renjith Pillai
February 23, 2015
Isn't that the right behaviour? The regular matching done for JIRA issue key definitely looks for a whitespace after the issue key. So the commits that you do in the UNITCLASS-5-code-cleanup branch should include the issue key (UNITCLASS-5) so that this match is successful.
johntholland February 24, 2015
For our workflow, it seems to make sense that when UNITCLASS-5-code-cleanup is merged into master, that it is finished, so we want it to appear as fixed.
