×Hi there, Hope all is well!
If a team has a company-managed project why would newly created issues not be automatically pushed to the Backlog?
In the project features setting Backlog is turned on - any thoughts? Does a sprint need to be created first with those issues assigned to unique sprints then it pushes?
Thank you!
Hi @Dylan Schofield ,
please check filter associated to your board in order to verify that it retrieves issue that you have just created.
https://support.atlassian.com/jira-software-cloud/docs/configure-filters/
Hope this helps,
Fabio
Hi Dylan - Welcome to the Atlassian Community!
Issues will go to the first status in the workflow from the Create transition. Take a look at your workflow to see which status that is. If it is the Backlog, then take a look at the history of the card to see if the card is getting auto transitioned to another status.
