×When i select create test, a create issue form is displayed. I select "Test" in issue type field. Then create but no form for test creation is displayed. Please could you help me about this issue?
Thank you for advance
regards
Hi and welcome to our Community!
I think you've forgotten about issue type screen scheme. In order to function properly, each issue type should have an appropriate create/edit screen assigned to it. This is accomplished through this:
Associating screen and issue operation mappings with an issue type
Please, have a look at it.
Thanks for your reply. It works fine now after following your link.
Thanks again for your help
