We've modified the jira fields and have removed priority. But all the default searches (by going to the project home page, issues tab and clicking on one of the links under "Status Summary") are still trying to sort via the priority field. How can I fix this?
Have you hidden "Priority" in the project's field configuration scheme?
See https://jira.atlassian.com/browse/JRA-30093for more info about this bug
Converted to an answer. You can mark it answered if it helped.
Thank you so much. It works.
Hello there,
Actually, the query performed when clicking on the links under "Status Summary" are automatically generated by JIRA and cannot be modified. Also, since the priority field is a system field I wouldn't recommend you to remove it :)
Clarissa.
