Why do I need to fill in a resolution when I edit an issue in a business project?
Dave Meyer
October 8, 2015
Dave Meyer
October 8, 2015
There is a known issue with the "Task Management" blueprint for business projects where the "Resolution" field is required and appears on the edit screen.
This means that if you create an issue in a business project using this blueprint and click the "Edit" button, you will not be able to update the issue without filling in the Resolution field. However, you can edit any field directly from the View Issue page by simply clicking on the field. For a more permanent workaround, see below.
This bug will be fixed in JIRA Cloud soon (October 19) and in JIRA Core 7.0.1.
Workaround
To fix this issue in existing projects, for the affected project, go to Project Administration > Screens. Then look for the screen "XYZ: Task/Management Edit/View Issue Screen" where XYZ is your project key. Click the link to go configure the screen, find the "Resolution" field, and click the remove button.
Lisa Zentz October 12, 2015
What is the blueprint for business projects and how is it used?
Dave Meyer
October 12, 2015
The new release of JIRA introduces three new blueprints for business projects, which are focused projects for non-technical users: https://confluence.atlassian.com/migration/jira-7/cloud_jira_product-changes From the description of the Task Management blueprint: "Create simple tasks, organize them and get them done. You can use this project to manage your tasks or assign them to someone else."
