I have set up an automation to update the fixVersion of issues after a release. This rule is triggered by another rule which ends with creating a new fixVersion.
Although the JQL for updating the fixVersion only returns less than 500 issues, I still find up to 50 issues that did not get updated with the new fixVersion.
I have tried to compensate for this by trying the same action a second time. This reduced the number of issues that were missed, but I still end up with 20 or so issues that are still stuck on the old fixVersion.
Hi @keerthi
Please uncheck the option "Only include issues that have changed since the last time this rule executed" as detailed in doc Automation rule is not executing the action on a request although the request is listed as part the JQL mentioned in trigger action.
Best Regards
Sam
Hi Sam,
Thank you for the suggestion. But I missed out on mentioning that I already had it unchecked and am still running into the issue
Hi @keerthi
You may be hitting a service limit
https://support.atlassian.com/cloud-automation/docs/automation-service-limits/
Best Regards
Sam
Hi @keerthi
Please check the audit log for your rule, as it is possible a rule like this could be running into one (or more) of the service limits for automation rules:
Hi Bill,
Thank you for the suggestion. I checked the audit log and there were no errors.
I read up on the service limits as well and I'm confident we aren't hitting any of them. For context, we have less than 10 rules set up on the project.
Interesting...
By the way: using that branch twice in the rule should not help...I would expect it to worsen the symptom you describe. The reason is that branches on one-and-only-one issue (e.g. branch to parent, current issue, etc.) get run in-line and so they complete before the rule proceeds with the next step.
But branches that could be on more than one issue (e.g. JQL, linked issues, etc.) get run asynchronously and in parallel. There is no guarantee they will finish before the next rule step. And so your issues in those two branches are possibly trying to update the same issues repeatedly.
Back to your scenario: let's try this test rule in the same place where your rule exists:
Now check if that contains the number of issues you expect. If not, there is potentially an issue with your rule scoping or the JQL.
Hi @Bill Sheboy ,
The number of issues that were written in the audit log turned out to be 100 which is way lesser than expected. I expected 308 issues.
I also eliminated the second branch for testing and noticed that 80 issues were left out. Which means 200+ issues got updated which is greater than the number returned from lookup.
Does lookup issues have some sort of limit?
Thanks, @keerthi for that information. I knew about that limit and wanted to check if it matched at least what you expected.
As I noted with the link about service limits, a branch can handle more than 100 issues but you could be running into a processing time limit. At this point I suggest you have two options:
Hi @keerthi
Did the 20 or so leftover tickets have anything in common? Did they all have more than one Fix version associated with them, perhaps?
If I was to troubleshoot this, I would start by looking at those 20 tickets in the JQL search list view. I'd have the status, labels, and fix version columns visible.
I'd want to start here just to confirm there wasn't a discrepancy between my JQL criteria and what tickets are being returned.
That's a great suggestion Josh. Thanks for that.
I will check the next time the rule runs. It might be a week or so until I check. Will give an update then.
Hi Josh,
The automation was run today and 24 issues did not get updated. I took a look at the properties but to see if they matched the JQL criteria and they do. They didn't have multiple fixVersions either.
The only common thing I could spot was that they were all created back in 2021.
I'm a bit lost as to why this isn't working as expected.
@keerthi Interesting. Are you able to share what the audit log entry says for the most recent run?
What is the scope of the automation? Is it limited to a single Jira project?
