Why does @mention not auto populate after 3 characters?
Kevin Dalton
Andrew Wolpers [BlackPearl PDM]
February 3, 2015
Where are your users being managed? Internal, Crowd or external LDAP? I know there have been issues with things like OpenLDAP and other sorts if not funneled through Crowd. If entered directly into JIRA as a directory it can have issues with timeouts and syncing.
Kevin Dalton
All users are pulled in through LDAP
February 3, 2015
What kind of LDAP?
Matt Hass February 3, 2015
Our instance uses Microsoft Active Directory (Read Only, with Local Groups)
February 3, 2015
Thanks Matt. I'd imagine you work with Kevin. Has this always been the case for you guys, or was this a recent happening? I'd really try to investigate and diagnose the connection between the two there. Sounds like something related to a timeout. If there is any additional authentication or firewalls it needs to jump behind you may be seeing an issue there.
Yep, I work with Kevin. Thanks for taking a look at our issue Andrew. Our users have reported this off and on for some time now, but I think this only began occurring after moving to v.6.2.4. We can occasionally reproduce this behavior. When this happens, the message returned is "No matching users found for dal" (when I search @dal to find Kevin). Sometimes, I get a full list of users beginning with 'dal' including Kevin. Sometimes the search will be blank, but will populate when I hit Tab. There is no firewall between the app server and the AD server, since both are internal. Timeouts are as follows: Sync Interval: 60s Read Timeout: 120s Search Timeout: 120s Connection Timeout: 60s Active Directory shows as having 43,535 entries. I can't find any recommendations for timeouts related to directory size.. Are there any suggestions based on proven practice as to what these numbers should be in relation to the size of the user directory?
Thomas Heidenreich
February 3, 2015
Probably because the user trying this does not have the "Browse Users" permission.
Kevin Dalton
All users have Browse User permission.
Thomas Heidenreich
February 3, 2015
Are we talking about a custom text field? In any case: the Wiki Style Renderer (https://confluence.atlassian.com/display/JIRA/Configuring+Renderers) must be active on the field for the autocomplete to work. Can you check that?
Kevin Dalton
Standard comment, just typing @ABC will not render any names even though we have many associates with those 3 letters
Kevin Dalton
JIRA 6.2.4
January 30, 2015
Kevin, what version are you on?
