Why is a simple feature, such as a Checklist for an issue not standard ?
right now everyone is forced to either create subtasks or subscribe to an extension ...
Hello @Martin_Kirk,
Issue Checklist Free is a completely free version of the Issue Checklist Pro app.
Both versions when installed are ready to use without any configuration required - just go to the Jira issue page and start using it.
In case of any questions or assistance required, we are happy to help.
Jack
Dear @Martin_Kirk,
I cannot answer your question, because we as Community Champions are not responsible for the road map of Jira Cloud.
Best you raise a suggestion at https://jira.atlassian.com
But while you are waiting for the implementation, you can create a couple of custom fields on your own and add them to the screen of one of your issue types:
Done - your Checklist is ready to be used.
So long
Thomas
I believe this only works for specific, repeatable generic checkboxes.. eg: "published", "tested", "approved by xx" ...
What i'd like is something like subtasks that you define yourself, that breaks down the story/task into smaller tasks that you can easily check off..
I guess the case against checkboxes is the ability to delete them or traceability, given that checkboxes doesn't get into the "flow" the same way as a subtask ....
