Why is JIRA automatically adding a project filter (project = 'xxx') to my filter used for the agile gadget?
Rao, Krishna October 16, 2014
I am setting up an agile dashboard using the classic agile gadget. I have defined my filter query to use with dashboard and the filter is returning the right result. However, the agile gadget is not display any data. Looking at the filter used by the gadget, I see that JIRA is automatically adding the following to the query.
AND NOT fixVersion is EMPTY - this is already documented
AND Project = 'xxx' - Not sure where this is coming from.
Because of the extra project filter, the query is not returning any data. Can someone shed some light?
Appreciate the help!
Krishna
Rao, Krishna November 17, 2014
The filter is automatically added by JIRA. If you have projects that are not showing up in the Agile gadget correctly, make sure you enable them under Add Ons / JIRA Agile / Enabled Projects
Cassi Cannon
November 17, 2014
I am seeing the same issue. Were you able to find a resolution?
Ramiro P
October 16, 2014
I have JIRA 6.1.6 and Agile 6.3.6 and I did some tests and there wasn't any problem. Just in case you should create a support ticket for this.
Ramiro P
October 16, 2014
You can go here: https://confluence.atlassian.com/display/AGILE/Using+the+Agile+Classic+Gadget and there's an option Report a Bug at the bottom.
Thanks for researching the issue and your recommendation.
Yeah, I am using the Agile Classic Gadget. JIRA version is 6.2.
Ramiro P
October 16, 2014
It seems like a bug. Are you using the Agile Classic Gadget? Which Agile version?
