Why is Smart Jira Project Config Docs plugin for Atlassian JIRA not available for my project after i
luana.fidalgo
April 12, 2021
Installed Smart Jira Project Config Docs plugin for Atlassian JIRA but is not visible on my projects.
Following the documentation i would have a 'Configuration and Documentation' tab which is not visible on my settings..
Eisonesoft
Dear @luana.fidalgo
In Jira Cloud you can access the smart documentation only under the Apps menu:
Hope this helps
Nic Brough -Adaptavist-
April 13, 2021
It is showing as enabled in Admin -> Manage apps?  Are you following the docs for the Cloud version of it?
