Why is a custom field editable when issue is in a state with jira.issue.editable set to false?
Klaus UNGER
If have set the property jira.issue.editable on a status FROZEN to the value false.
The edit button disappears and standard fields are locked from inline-editing, but custom fields remain editable.
Any chances to lock them down as well?
thx in advance
Deleted user April 11, 2016
Did you publish the workflow with this workflow property? Is the project using this workflow? Can you double check what status did you put the property?
Klaus UNGER
Yes, doublechecked everything, published, assigned ... everythings fine.
I just noticed that the behaviour is correct after a reload.
Directly after pushing the "freeze" transition button, the Edit button is gone, but the custom fields are editable.
Klaus UNGER
But saving results in an error message. So it is just a minor rendering issue.
So this is actually working now? It might be a browser cache issue then?
