Why is issue type description not displayed?
mamamic April 7, 2015
I've created my own field configuration where I edit descriptions for certain fields.
all of them seem to work except "Issue Type" one. I am running a relatively old JIRA instance (version 5.2) but this i cannot change because of a coorporate licence.
Any ideas why this happens?
Chandra Sateesh
The description does not display in the issue creation screen. I tested in 6+ version as well
Is this by design or a bug that I discovered?
Chandra Sateesh
It is by design.
Sorry, could not reply since i need more than 25 points to post more than 3 messages in 24 hours?!?!? So, the question is - why do you have a details text box under issue type field then?
Chandra Sateesh
I am aware the custom fields Description is visible in the issuenavigator. But not sure of this. I will check and get back
mamamic April 8, 2015
Sure, thanks. Let me know when you have something
Chandra Sateesh
Hi
Where do you want the description to appear. Is it during the issue creation or in the excel report.
It's the issue creation screen
