Why is my comment not visible after a issue transition to closed?
Janine Bohnenberg January 29, 2015
i have a transition named "Close Issue". I assigned a screen to that transition which allows me to add a comment when i transition my issue from any status to "Closed". Unfortunately that comment is not visible in the comments section or in the activity stream.
I checked the screen with other transitions. The comment is visible. I did not found a clue about my problem via internet search.
Regards
Madhur Bhatia September 20, 2019
All my transitions have a post function "Add a comment to an issue if one is entered during a transition."
But  when i enter my comments on the transition screen, it does not show up on the issue screen
Valentin Lévrier
November 6, 2019
I have the same problem, I want the comment to be mandatory when making a particular transition, made the needed screen, it displays as expected and all but when I validate my comment on transition screen it doesn't appear on the issue display screen and I must write it again...
Maciej W April 29, 2021
Got the same problem.
In my case it was due "finish"/"Closed" status property jira.permission.comment.user which was set as "disabled"
Khushal Chate
October 1, 2020
Hi Can anybody add the Resolution here?
Jyoti Bisoi September 20, 2019
Is it resolved?
Andrew Harwood September 11, 2019
Same problem.
Jyoti Bisoi January 6, 2019
same issue, Please suggest
Tommy Cordery
August 3, 2018
SAME PROBLEM!!!!!
Mikko Salama January 2, 2018
Exact same problem here, if I transition the ticket open the comments are visible again.
Matt Shelton
I'm having the exact same problem – let me know if you figured this out!
Nic Brough -Adaptavist-
January 29, 2015
Could you have set the comment visibility to a restricted group?
When i added the comment, the visibilty was "Viewable by All Users". Apart from this i can see all other comments that where made on transitions.
January 29, 2015
Ok, this sounds like it simply hasn't added the comment at all. I would check your log file for warnings and errors at the time you performed the transition, but my best guess is that you accidentally cleared the comment before committing the transition.
I will check the logs. Iam sure that i did not cleared the comment. I tested it too many times. :)
