Why the comment can not be synced between JIRA and Zendesk(another bug management system)in these two days?
Huali Yang August 27, 2012
T G August 29, 2012
Apparently there is a bug in the integration according to zendesk support. They have been trying to set up a demo with me with JIRA 5.1 and their zendesk, the comments aren't integrating. They upgraded their integration and it broke this I believe.
Nic Brough -Adaptavist-
August 27, 2012
Er, you probably need to give a lot more detail, and probably contact Atlassian OnDemand support. We don't know what comment you are talking about, where it is and you almost certainly need to read the log files.
I know The comment can be synced at last week, but from yesterday, can not, no any logs and errors can be found. The comment is about JIRA issue and very common words.
August 27, 2012
You still haven't given any more detail that we can work with.
We need to see your configuration, your log files, what the comment is, where it's appearing (and where it is failing to appear), what you've changed and so-on
I say again though - you almost certainly need to contact Atlassian OnDemand support. You've used that flag on your question. If that is wrong and you are running your own server then please change the tags to something more representative, and look through the log files. If it is correct and you are on OnDemand, then you need to talk toAtlassian.
