Will Azure DevOps for Jira allow me to sync my projects under my Azure organization?
Aleena Umaiir
I want to move projects from multiple Azure organizations to a jira instance, with all issues, and everything migrated, and then syncing of all on regular basis.
I am observing that it is a free tool, will this free tool allow me to do all of this?
Alex Koxaras -Relational-
Hi @Aleena Umaiir
Syncing issues among projects between Devops and Jira is a cumbersome procedure. I kind of doubt that there could be a free tool doing this. I know for sure that Exalate is doing this job superbly, but it's not free. Can you share the link of that free app?
Aleena Umaiir
This is a tool to sync you deployments and builds. Not for issue syncing. If the former is what you are looking for, then most likely it will do what it states. If you are looking for syncing issues, then this app is not for you.
Aleena Umaiir
Thanks @Alex Koxaras -Relational- , I am exploring Exalate now
Like # people like this
Dhiren Notani_Exalate_
August 23, 2024
Hi @Aleena Umaiir ,
Thanks for posting your question here!
I am Dhiren, one of the Solutions Engineer working at Exalate.
Exalate is a completely decentralized bi-directional integration solution which can help you sync all Azure WorkItems from different projects (across multiple organizations) to Jira Issues.
It provides you an access to it's Groovy based Scripting Engine through which you can choose what information you want to share from one side and it's very customizable.
You can sync issue types, custom fields, and even replicate issue hierarchies(links) and stuff like Sprints/Iterations.
We do provide a customized demo based on your use-case and also provide a 30 day free trial to evaluate the product.
Let me know if you need any more help on information!
Thanks, Dhiren
Diana_Architect_ZigiWave
@Aleena Umaiir , hi! Just to add another possible solution you'd might like to explore - check out ZigiOps in the Atlassian marketplace.
It's fully no-code integration platform that will help you connect and sync your Jira -Azure DevOps instances with their data. With ZigiOps, you can sync your projects under Azure easily. + ZigiOps does not store any of your data. Feel free to explore it and even try it yourself by the Free Trial option.
Regards, Diana
