Will HP ALM Synchronizer 12.55 supports JIRA V7.9.1 upgrade
Satish Tatikonda May 3, 2018
Please provide details if anyone tested this sync
francis
Exalate is an issue synchronisation tool allowing to synchronise defects from HP ALM to Jira (including 7.9.1)
If you would like to have more information on the capabilities of Exalate - please feel free to book a meeting at
https://exalate-demo.youcanbook.me
Francis
Shibin Shaji George October 12, 2018
hello,
yes the Sync V12.55 will work with the version of JIRA you want.
note : better to use the latest version of sync plugin in order sync the data.
also, make sure that you have access to the JIRA website if you are trying to setup sync in the server because if you cant login to JIRA from server then you wont be able to connect from sync as well
