At the moment we use Tempo Planner as well as Tempo Timesheets. I would like to deinstall Tempo Planner and just keep Tempo Timesheets. Will this effect our data? Furthermore, if we decide to go back to Tempo Planner in the future, will our data still be available?
@Tempo SupportMaybe you can help?
Thank you :)
Kathrin
When only removing Planner, your JIRA instance will stay connected to the Tempo database via the Timesheets app.
Tempo Planner and Tempo Timesheets share the same database, and no data will be removed when you uninstall Planner.
Users will also still be able to view their own plans in their "My Work" view.
When re-installing Tempo Planner at a later time, all data will be available.
Best regards,
Susanne Götz
Tempo team
Thank you :)
