Received product owner role but still unable to change status of issue.
Same with Squad member role, but in Project Permission description mentioned that one of those roles able transit issues
Hi @Svetlana Maklakhova and welcome to the community,
You have to also inform us if there is any kind of message you are getting when trying to transitioning the issue. In addition, is the transitions visible to you or not? If not, then most likely a condition occurs within the workflow which prohibits you from transitioning the issue.
Hello, Good day. Kindly let us know whether you are using Team managed project or company managed project ?
I asked for manulife company Jira board.
For one ticket I unable to change status. I guess something went wrong when this ticket has been moved from different board.
Also, I was unable to contact to Jira Administrator.
While I try call Contact your Jira admin system response that administrator has not configured.
Thank you in advance
As this issue is noticed on one specific issue. We can check the HAR logs from the browser to find the error. https://confluence.atlassian.com/kb/generating-har-files-and-analyzing-web-requests-720420612.html
Thanks. Do you see any 4xx or 5xx error message?
@Mohanraj Thangamuthu
Sorry by company security wall I unable to send HAR file. So, I will input console info by copy-past in message body.
403 Forbidden error
ASD-63:1639
GET https://media-cdn.atlassian.com/ap-southeast-1/v1/cdn/file/a19eef02-e50e-47c5-808b-532b2a52010f/image?allowAnimated=true&collection=&height=0&max-age=2592000&mode=full-fit&upscale=false&width=4096&token=eyJhbGciOiJSUzI1NiIsImtpZCI6ImdlbmVyaWMta2V5cGFpci9kdC1hcGktZmlsZXN0b3JlL2Nkbi1hdXRoLS1wdmgwMm5pbmJqZHFnNmtuIn0.eyJzdWIiOiI4YWJmM2FmMS03ZTViLTQ0ODAtYjE2OC1jNmUwYTYyMTdiNGEiLCJleHRJZCI6ImExOWVlZjAyLWU1MGUtNDdjNS04MDhiLTUzMmIyYTUyMDEwZiIsImludElkIjoiYTE5ZWVmMDItZTUwZS00N2M1LTgwOGItNTMyYjJhNTIwMTBmI... 403 (Forbidden)
400 Bad request
index.tsx:50
POST https://manulife-asia.atlassian.net/rest/internal/2/log/safe/error 400 (Bad Request)
409
Failed to load resource: the server responded with a status of 409 ()
jira.user.issue.has.seen.quick-actions.change-boarding.message:1
hasDismissedConfluenceDummyLinkCrossJoin:1
/rest/api/latest/user/properties/jsw-pp-end-user-activated-confluence_v2.seen?accountId=712020%3Ab5d0e1cc-d3e3-4f41-8a17-fd3e60a54e42:1
/rest/api/latest/user/properties/JpdRecommendationDismissed?accountId=712020%3Ab5d0e1cc-d3e3-4f41-8a17-fd3e60a54e42:1
start:1
Thanks. Given 403 error is for CDN and I don't have any entry related to issue transition. Please raise a ticket at https://support.atlassian.com/contact/ we will check further on this issue. Thanks
