×Hi friends,
I have the work flow for my project like when we create the issue it is moved to the closed. Now i want to add the transition for the closed step. But it does not display the "Add Transition" in operation. How can i add the transition for the "Closed" step.
I added the screen shot of it.
Thanks in advance,
karthik A.
screen shot: In operations column there is no Add transition how can i enable this one?
Hi Bharadwaj,
i add the new step "Open", from that i can able to move to the "closed" but still closed state does not get the "Add Transition" Operation.
Karthik A.
you go for diagram representation and try.
You can't add a transition to a status that has no outgoing transition in an active workflow. Make a copy of your workflow, then add that transition and replace the old workflow with the new one.
I done the modification but still the the "Add transition" is not available in the Operation.
please refer the screen shot.
You have a couple of possibilities:
it should be like this.
The work flow is only used for logging the meeting information of ours so after creating the issue, it will set into closed status like a way we are create the workflow. Whenever we are create the issue,it will moved into closed. Now we want to edit some information on that issues. so i need to open the issues. so i tried to add transition on that "Closed" but the Operation is not available.
Diagram of the workflow:
How can i add the transition on the closed status.
First you need to add a step named Open, then add transition on Closed to Destination step Open.
I posted an image.
Are you having just the Closed status in your Workflow? If yes, then what is the starting point for the transition? Add more statuses to the workflow and then add transitions.
yes you are right Renjith, I missed the id of Closed.
your workflow might be active now. Make a draft of this, add transition and publish the draft.
