The Your work --> Worked on on section displays all the items you have worked on in the last month and the type of work such as Commented on, Updated, Created. I'm recreating this on a filter and dashboard to obtain > 1 month of this data. Is there a way to add the type of work (Commented on, Updated, Created, etc) to the filter/dashboard? Thanks!
Hi! You can try Activity Stream (dashboard gadget)
