I am having trouble with a certain scenario. I am trying to limit transition of an issue if the current user is the reporter AND a certain field(CR Priority) is set to a certain value(Low). Appreciate the help!
Hello @faizulc
You can not do it outofthebox.
You can do it with some plugins like Scriptrunner or PowerScripts.
https://marketplace.atlassian.com/apps/6820/scriptrunner-for-jira?hosting=cloud&tab=overview
