×Hi Team,
we want workflow level integration between JIRA Software & GitLab where if status gets a change in one tool should update status in another, This integration is possible or not.
Please help me with this issue.
Venkatesh.K
Hello @Venkatesh Kundelu ,
Searching the marketplace I can find some add-ons to integrate Jira with Gitlab:
However, going through the results, I think the only one (or one of the few) that provides 2 way integration seems to be: Sync Jira with GitLab
Please review above add-on and also the other search results. Together with that, may also review the below links:
I hope this helps.
Dario
