×Hello community,
I have a workflow for example
To Do ---- Open ---- Analasysis--- In progress------
The question is the person was able to switch directly from open to in progress between states missing. Is this is the fault in work flow or somewhere ?
Thanks!!!! In advance
souhnds like you have an arrow directly from open to in progress
can you post a screen of the workflow, like this one
Hi @Raju
Workflow is totally configurable depending on your need. For ex, in simplified workflows you can jump any status. On the other hand, you can configure the statuses sequentially.
For your case, you should remove global incoming transitions for each status and add transition from status to status. Btw, do not forget to publish it.
Also take a look at this doc.
Best
