Workflow transition problems in Jira 5.2.8
sap
March 17, 2013
We had installed the latest Jira 5.2.8 version and the jira misc workflow plugin version 2.5.5.2.
However when i tried to edit an existing workflow i found that
if i wanted to give a validation in a transition and chose the condition "Fields required" then i am unable to add the field as such.i.e.,this option isnt allowing me to add a field for validation.i also tried with plugin versions 2.5.4 and 2.5.2 but with no avail.
Has anyone faced such an issue in Jira 5.2.8?Is there a way out for this?
Pedro Cora
March 18, 2013
sap
March 19, 2013
Hi Pedro,
Sorry to have given the wrong info.
I had later tried out the version 1.3.4 and 1.3.5 of suite utilities but still i am unable to select the fields for the component "Fields required" in Jira 5.2.8 in IE8.However this issue isnt seen in Firefox browser.So is this a problem with the Jira version or is there any work around currently
sap
April 9, 2013
This issue has now been fixed by atlassian but would only be available from confluence 6 onwards.Till then the workaround is to use firefox browser for this.
