Would like to specify fields to display for single JIRA issue
Wendy Fergusson April 14, 2014
The JIRA Issues macro displays a single JIRA issue with the type, key, summary, and status. We would like to be able to configure which fields to display for a single JIRA issue.
I thought I saw mention somewhere that this enhancement was planned, but I can't find it now so I'm not sure whether I'm remembering correctly.
Anyone know whether configuration of fields for a single JIRA issue is planned or at least already requested? If not, I'd like to request it.
Adam White June 2, 2014
This is sort of out now in 5.5, but you can only customize the fields in a table, not the normal single issue macro.
Wendy Fergusson June 18, 2014
I guess that'll have to do.
I found a way to fake it before 5.5 as well (format JQL query as "key = <blah> or <field> = <something valid but never true>" - forces it to display the single issue in a table, where you can specify the fields).
Sneedy McCreedy
July 27, 2016
This appears to be the case, and it is woefully inadequate for producing professional-quality documents out of Confluence.
This at least is the case when using ScrollOffice, which embeds the field in a table and gives the field name as the column header, which unfortunately is made all lower-case (regardless of its case in Jira).
The result is that every time I want to create a new version of my Word document, I have to go into it and 1) manually convert those tables to text, and 2) remove the redundant content. That is a manual intervention that shouldn't be necessary, and it's time-consuming.
It would be good for Confluence to improve the macros for pulling in JIRA content (eg allow for the presentation of a single JIRA field without using a table), and for ScrollOffice to improve its templating ability. We need more fine-grained control.
