First I am NOT a developer and I always write my groovy expression with what I find here in Atlassian answers. But not this time
I am trying to set a number custom field with a negative value. It is only done if another custom field has the "Non" value. Plus I will have to make sure that the custom field number is not already negative.
I tried different combinaison and I am not able to change the value of the field named Montant.
issue.getCustomFieldValue("customField_19313") or issue.get("customField_19313") * -1
I really don't know what to try next. Any help will be appreciate.
image2017-2-13 15:3:14.png
Try this one
import com.atlassian.jira.component.ComponentAccessor import com.atlassian.jira.issue.fields.CustomField CustomField montant = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Montant") double curValue = issue.getCustomFieldValue(montant) if(curValue > 0) { issue.setCustomFieldValue( montant , curValue * (-1) ) }
I will keep your answer but the client has decided to not do this.
Thanks for your time, much appreciated.
