Hi all!
I've got a problem exporting cucumber tests.
I'm performing request like:
curl -H "Content-Type: application/json" -X GET -H "Authorization: Bearer [MY_TOKEN]" "https://xray.cloud.xpand-it.com/api/v1/export/cucumber?keys=[TEST_PLAN_KEY]"
Where TEST_PLAN_KEY is actually existed test plan with cucumbers tests contained.
And the response I get is:
{"error":"Server Error - Error processing JQL batch search results - 403"}
What might be the problem?
This error suggests permission related issues.
Please contact the Xray Support (http://xraysupport.xpand-it.com) so that we can request additional information to help you.
Thank you.
Rogério
Hey Rogério,
I'm facing the same issue in my project. Do you know what might be happening here?
Best regards,
Sebastian
It is best to contact Xray Support (http://xraysupport.xpand-it.com ) so that we can request additional information and help further.
It is necessary to troubleshoot the cause, and the best approach is to have a support team member handling your case, since causes may differ from one instance to another.
Rogério Paiva [Xray Support Team]
