I have the Add-on Xporter for JIRA Cloud and am trying to export test cases with the detailed test steps. However, all formats simply give me the top-level view with out the detailed test steps. I have added the Test Step Column to the Issues Search screen. Looking on line it appears Xporter has this capability.
Cynthia, you should not post an answer to your original question instead of posting a comment to an already existing comment.
I can confirm you are using Zephyr.
We have an add-on called PDF View Plugin that exports Zephyr test steps, executions, step results to PDF, although that isn't an immediate solution for you (not being available for cloud yet).
I don't know about any JIRA Cloud add-on that exports Zephyr information, sorry.
okay - revisited the screen...Test Step was indeed a Custom Field. What I am trying to export are the Test Details aka Test Steps
Based on this screenshot, are you using the Zephyr add-on for test management?
That's important to know for the correct answer.
I do not so. It is the section that is there when we created the Test Cases
Can you share a screenshot? Is that field created by another Add on?
Hi, Is the Test Step a custom field?
