Xray/Gherkin suggestion dialog for Jira
Benjamin Laschkar
June 22, 2023
I don't have the dialog box for highlight suggestion when I try to implement a cucumber test in guerkin.
It also does not appear when I type ctrl+space.
Is it provided on xray 6.1.4 + jira v8.13.22 ?
Manuel
November 9, 2024
HI @Benjamin Laschkar ,
you need to update your Xray version. Then you can use that feature whenever editing cucumber tests or preconditions.
Btw: it seems that you're using Jira server/dc and not cloud, as wrongly appears on the tags of this question.
