is it traceable which Test sets are used to fill the Test Plan, or do I have to listen to links to be able to understand them ?
or Is it possible to create more Xray Test Sets Panel ?
Hi @Charlie
A Test Set is not more than a flat list of Tests, so when added to a Test Plan, only the Tests will be linked, since between Test Plans and Test Sets there is no link.
So to see from which Test Set a Test belongs to, just need to add the column "Test Set association with Test".
Best Regards,
Team Xray
