×Hi, I have a question regarding Xray performance while it loads test runs more than 1000 tests (refers to this documentation: https://docs.getxray.app/display/XRAYCLOUD/Traceability+Report ) in the Performance section. Is it still an issue or it has been fixed? Because I don't know if the documentation is updated or not.
HI @Fathir Wafda ,
You may want to post in apps and integration section (https://community.atlassian.com/t5/Apps-Integrations/ct-p/atlassian-marketplace) to possibly get more traction to your question. Usually, these type of questions, I would just contact Xray support directly to get the answer. They usually answer fairly quickly from my past experience.
thanks,
Ben
Thank you very much for your direction @Benjamin .
I don't know there is a specific section for this. As you suggest, I would ask my colleague who acts as the person in charge to contact Xray support directly.
Thanks again for your help.
No problem. Welcome to the community.
In my case, I haven't found it very common to show 1000 Runs in a report. It might even be hard to read and use for presenting insights on the test data to act upon. Do hope that limitation has been resolve and able to proceed with your needs.
-Ben
